I have a PCSGU250 - and the values shown on the 2 channels are different.
If I connect both probes to the same source - the DC-MEAN, MAX, MIN are different.
I switched the probes (connections) to identify if the mismatch is coming from the probes.
- same result. The channels show the same values - independent which probe is connected
(so the probes can’t be the failure cause)
I did several calibrations - no improvement.
Channel 1 is very close to my DMM. So I assume channel 2 is not correct
Is there any adjustment possiblity (maybe in an inifile - or so ?)
Thanks in advance
pwo
P.S: here example values
Channel 1 / Channel 2
DCMean 4,97V / 4,88V
Max 5,06 / 4,97V
Min 4,97 / 4,88
Pk-to-pk: 0,09 / 0,09
P.s.S:
Software is running on a XP home / SW-Version 1.12 / Firmware 1.01
