Does PCSGU250 work with win 7 64-bit? If not is there an update comming?
Yes, the PCSGU250 works with win 7 64-bit.
You have to download and install the latest software and the driver from:
velleman.eu/support/download … U250&type=
I have the unit and have installed the software you mentioned multiple times, restarting in between. The program says it does not get any contact with the USB-port. I have taken the connetcor out and in several times with the same result. What am I doing wrong?
I just extracted and ind installed the USB driver from Control Panel and Hardware.;Update driver and directed it to the .inf-file. Now it seems to work. I will check it out tonight.
Do you see ‘PCSGU250’ in the Device Manager either under PCSGU250 Device or under Custom USB devices?
If not or if there in a yellow exclamation mark, then you have to update the driver.
Here you can download the instructions how to install the driver in Windows 7:
box.com/shared/zjo7oskrpg
Here you can download the instructions how to update the existing driver: box.com/shared/66aei7j31s
