I find that the output voltage of the function generator as measured by a digital voltmeter or an oscilloscope is substantially higher than that indicted in the PC display.
For example, with a pure 165Hz sinewave output and display indicated voltage = 2.86 volt rms and 8.09 volts p-p, and offset = 0.00 volts, the actual measured voltage as determined by my scope and digital voltmeter is 3.33 volts rms.
Your comments on this large error will be appreciated.
Please download and install the latest software to fix the problem.
The software is available here: velleman.eu/support/download … u250&type=
Also the latest drivers are there.
The downloads package contains the right PcLab2000LT version 1.12.
You can do following:
Uninstall the PCLab2000LT v1.01.
Then delete all the files in the folder C:\Program Files (x86)\Velleman\PcLab2000LT
Then install the downloaded software version 1.12.
