PCS64I scope
Hello, is it possible to use a PCS64I scope with a windows 7 ?
Thanks for answer, Pierre
Should be possible in 32-bit version of the Windows 7 only.
Windows 2k/XP/Vista/7/8/8.1 32 bit: Yes, both the DOS and Windows program.
Windows XP/Vista/7/8/8.1 64 bit:
The DOS program won’t run because there is no DOS. You may try using a shareware DOS emulator.
The Windows program won’t run without precautions because parallel port access is unluckily done using dlportio.sys which won’t run on 64-bit systems. But the inpout32.dll solution as described for PCS500 should work for PCS64i too. See this forum: PCLAB2000SE v3.1, DriverLINX problem - #11 by daveben - PC Oscilloscopes and Recorders - Whadda forum - Community Help and Support
