PCS500 Calibration Hangs
I’m having a problem with calibration of my PCS500. The software (PCLAB2000se) load fine and recognizes the device on the LPT port but the software hangs during calibration and CPU resources are 100%. The only way to get out is to kill the application in the task manager. I have changed the ports setting of LPT1 to the various choices available:
AT
PS/2
EPP
ECP
None of these appears to make a difference.
I’m confident the PC is not the issue (Dell Optiplex GX280; Windows XP SP3) as I had PCLAB2000 (ver 1.3) running on the system. I had several unsucessful calibration attempts, but I upgraded the software to the se version because the application would take several minutes to launch.
Any advise is appreciated.
Thanks.
Jon
You may try this: Delete the WinDso.ini from the folder where the PcLab2000SE is installed.
Then try again to run the program.
Vel255,
I tried that several times as well but got the same result.
This is strange problem.
One workaround to get the scope running is to install the old version of the PcLab2000.
  • calibrate the scope
  • install the new SE version
    The calibration results stay in the WinDso.ini
