Try to get the PCS100 working on a CTX EzBook (Pentium 150Mhz-Win98)on LPT port, but does not want to work, says:is not connected.
The LPT poort is availble in System/Hardware, also is present in the Bios set as standard port.
I have tryed all the addresses, help!
The PCS100 works fine on my windows WP PC!
Do you know a solution?
Thanks, Johan.
Have you checked the LPT port address?
If it is 378, 278 or 3BC then it should work just selecting it from the list on the startup screen of the PcLab2000SE.
If the address is something else then it must be entered to this combo box.
See these threads too see how to check the LPT port address: viewtopic.php?f=15&t=3076 viewtopic.php?f=10&t=2154
