The PCS10 slowest sample rate is 1 measurement every 10 seconds. I need to test for a period of 3 days. If I select autosave does the information remain even when the analogue display resets?
Can I slow the sample rate further (say by adjusting a value in a ini file somewhere?) so I get my complete test on the analogue display.
[quote]I need to test for a period of 3 days. If I select autosave does the information remain even when the analogue display resets?[/quote]Yes.
[quote]Can I slow the sample rate further (say by adjusting a value in a ini file somewhere?) [/quote] Sorry, this is not possible.
You can use File -> Open Data to view the recorded data on the display. You can use the arrow buttons next to the horizontal scroll bar to view “multi screen” data file.
