I purchased PCS10 and installed PCLab2000 on my PC working on Windows 8.
I can read measurements and record data in txt files which I can then read (but as a curve) again by the command Open Data of PCLab.
But what looks strange is that:
[list=]if if started PCLab as administrator I cannot have access to the files I created although the Open data opens the correct directory
I can open and find the files when I start PCLab as simple user
but in all cases I can’t find the files in the directory with windows explorer and I can’t either open the txt files with Excel as Excel does not find the files in the directory! [/list]
When run as administrator, the files are located in the folder: C:\Program Files (x86)\Velleman\PCLab2000SE\data
If not run as administrator, the files are located in the folder: C:\Users<username>\AppData\Local\VirtualStore\Program Files (x86)\Velleman\PCLab2000SE\data
Pour le contrôle de 24 batteries de 2 V plomb , j’ai besoin d’un control par cellule.
Votre PCS10 est intéressant .
Il m’en faudrait 6 unités pour faire le contrôle des 24batteries FLA de 2V .les 6 unités seront donc raccordées avec 6 entrées usb d’un pc .
Votre systeme existe en version 8 ou 16 entrees ?
Est t il possible de faire une alerte en cas de dépassement de la valeurs max ou minimum ? Par ex, un relai ou un email ou une commande push , html, ftp ,… ?
