I have a PCS10 logger and want to record some signals that are relatively short in duration (.2 sec). I am using a time base of 1S and can see the pulses no problem when recording. My problem is that I can only see 17 seconds in time. I have tried using Autosave and click the Run button when recording is done. So in my case lets say this is 2 minutes. I then go to File>Open Data and open the folder I created in Autosave as test. The problem is I can’t see all 2 minutes of recording, just one screen length or a 17 second snapshot, which appears to be the last 17 seconds. Using the scroll bar takes me off into no recording.
If I go into File>Open Data I notice that the text document has a padlock on it. If I go to My Computer>C>Program Files(x86)>Velleman>PCLab2000SE>data I see no text files to open as a text file or in Excel. If I approach them from Excel or Notepad they can also not be found.
Am I doing something wrong or have I just simply missed something???
Updated software from 2.00 to 4.04 still same problem.
[quote]I then go to File>Open Data and open the folder I created in Autosave as test. The problem is I can’t see all 2 minutes of recording, just one screen length or a 17 second snapshot, which appears to be the last 17 seconds. Using the scroll bar takes me off into no recording.[/quote] You can view the whole record using the arrow buttons next to the horizontal scroll bar.
For more info please see: viewtopic.php?f=10&t=6619 viewtopic.php?f=11&t=8105 viewtopic.php?f=18&t=6831
[quote]If I go into File>Open Data I notice that the text document has a padlock on it. If I go to My Computer>C>Program Files(x86)>Velleman>PCLab2000SE>data I see no text files to open as a text file or in Excel. If I approach them from Excel or Notepad they can also not be found.[/quote]In Windows Vista (and newer operating systems) the files are located in the folder:
C:\Users<your username>\AppData\Local\VirtualStore\Program Files\Velleman\PcLab2000SE\data
In 64-bit OS version:
C:\Users<your username>\AppData\Local\VirtualStore\Program Files (x86)\Velleman\PCLab2000SE\data
In Windows XP the files are located in the folder C:\Program Files\Velleman\PcLab2000SE\data
[size=85]“Windows Vista improved application compatibility for standard users by redirecting writes (and subsequent file or registry operations) to a per-user location within the user’s profile.”[/size]
