PCS10 device not found when turning off computer
Hey guys,
i am having the pcs10. i am developing an application in C# and reading data from the pcs10 which works fine.
The only thing that i am wondering how to solve is, that everytime i turn off my computer and let the pcs10 plugged in it is not finding any source to read the data from.
so i have to plug out the pcs10 and replug it and then it works just fine.
Is there any workaround for this problem, that i do not have to plug it out???
thanks so far :slight_smile:
Iโ€™m sorry, I canโ€™t reproduce the issue.
I tried with Windows 7 (64 bit), Windows 8 (32 bit) and Windows Vista (32 bit) PCs.
In every case the PCS10 was detected by the PcLab2000SE program after the PC restart.
What operating system are you using?
A workaround may be using a powered USB HUB.
i am using Windows 7 32 - Bit version as OS.
so its just a usb Port issue?
[quote]so its just a usb Port issue?[/quote]Yes, I think so.
ok :slight_smile: i will try it with a powered usb hub :slight_smile:
