Starting PcLab presents a new Error:
Environment: Microsoft Windows [Version 10.0.19042.685]
Pclab and drivers are installed from the most recent sources of Velleman.
USB-View tells device is properly connected.
The message is permanent, each time PcLab is started the message is issued.
After the first occurences it was not possibke to start the oscilloscope application successfully. No oscilloscope detected was the message and the advice to pull and reconnect the USB plug. Without success.
But suddenly after some trials the connection to the scope was found and the application worked fine (at least for the current Windows session, I haven’t done a reboot up to now). It was possible to stop the PcLab-Application and launch it again several times. But the message is permanent and appears at each launch.
