It appears that PCLab2000LT (using on Vista 64 dual core Intel HP Laptop with NVIDIA GeForce 9600M GT) is stuck minimized upon startup (both with and without PCSGU250 USB device connected).
It used to work about 2 months ago (when I last used it almost everyday for many weeks).
I uninstalled PCLab2000LT and re-installed it. Also, I downloaded a fresh copy of PCLab2000LT V1.06 just now and after uninstalling and re-installing it, it still does not work (still does not come out of being minimized).
Is there some sort of configuration setting that stays around between installs that keeps it from painting properly?
The only thing that I can think of that may have changed is that Microsoft auto updates may have updated the nvidia driver.
Regards,
Todd
Nevermind…I have two displays…when I moved the external display to the right of my “home” display and the application remembered that I last placed it on the display to the left of my “home” display…it paints it off both screens. Once I moved the external display (in Display Personalization settings) back to the left of my “home” display, it showed up again - at which time I moved the app window back to my “home” display. Now I “see” it (the application painted the main window).
