Ik kocht in 2014 een PCSU200 (PCLAB200)
Met windows8 ging het mits enkele moeilijkheden heel goed.
Nu heb ik windows10, en niks werkt nog, enkel de demo.
Wat is de oplossing ?
On 64bit Windows you have to disable the driver signature enforcement to install the driver.
Here you’ll find the instructions how to disable driver signature enforcement on Windows 10:
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
You can use the driver located in the folder:
C:\Program Files (x86)\Velleman\PcLab200\PCSU200Driver
To install the driver, follow the instructions in the “PCSU200 Driver Installation.pdf”.
This document is included into the software installation package:
http://www.velleman.eu/downloads/files/downloads/pclab200_v1_05_setup.zip
