Pclab installation problem
i have extract in a folder and i have run setup.exe, but don’t work, i haven’t an error message, the cursor on a screen is blocked
now i use a pclab2000 version 1.30
i tink tha the problem is the file:
wowexec.exe
setup.exe
the process in the task manager is always running, because i can’t erase the file before to finish the process.
I download a new version of pc lab 3.05, but it’s the same.
One solution may be to install the software to other PC and then copy the installed files to your PC.
Copy the whole C:\Program Files\Velleman\PC-Lab2000SE folder and following files from the SYSTEM32 folder to your computer’s SYSTEM32 folder:
DSOLink.dll
PCSU1000D.dll
DLPORTIO.DLL
DLPORTIO.SYS
PCGU1000Link.dll
FASTTime32.dll
CP210x.dll
FTD2XX.dll
i have do this, and it work for now , but i haven’t find the problem ! :?:
