is it possible to add a sweept mode for each library function.
Would be very usefull for my application.
THX for support
Sepp
THX for support
Sepp
That was so good idea that I immediately tested it. - Works fine.
Now there is one check box added to the Sweep window: “Sweep selected waveform”.
You can sweep any library waveform, square, triangle, noise etc…
To sweep any library waveform do following:
Click “More Funct.” button.
Click “Sweep” button.
Check the “Sweep selected waveform” check box.
Click “Lib” button in More Waveforms window and load the library waveform.
Click “Sweep” to sweep it.
Set proper start and stop frequencies and the sweep time as usually.
You can download the updated files from: vel255.diinoweb.com/files/PCSU10 … ep_all.zip
Copy the files to the PC-Lab2000SE folder (normally in C:\Program Files\Velleman…).
In the further test one “known issue” found: You have to adjust the amplitude of the library waveform after loading it and before you click the Sweep button.
This will be fixed in the final release.
Works fine, thanks a lot.
One little thing:
The window that shows the current waveform allways shows a sine,
not the selected libary file.
Both things: The amplitude setting and the waveform display will be fixed in the final release.
Please,help me. I have a question:
Is it possible to initialize and work with the PCGU1000 without using the FGU.exe file? Is there any function in some .dll files which initializes the PCGU1000?
Thank you.
