Pcgu1000
i am having trouble locating a driver for windows 8.1 the usb device is not detected also in the set up screen it says install_drv.exe anyone have any ideas i have check the web site and loaded the most current driver- mike
In 64bit Windows 8.1, you have to disable the driver signature enforcement to install the driver.
Here are the instructions how to disable the driver signature enforcement in Windows 8.1:
howtogeek.com/167723/how-to- … d-drivers/
I think you download the latest software package and the driver from:
velleman.eu/support/download … 1000&type=
You can use the driver: “PCGU1000 USB driver for Windows XP (32- and 64-bit) / Vista (32-bit) / Windows7 (32-bit)”
This driver can be used after the “workaround” for 64-bit Windows 8.1 too.
In the software package there are three files:
[color=#000080]PcLab2000SE_v4_05_setup.exe[/color]
  • Run this software to install the PcLab2000SE v4.05
[color=#000080]Release Notes.pdf[/color]
  • Includes instructions how to update the USB driver.
  • Please see this section: “Workaround to use the PCGU1000 on 64-bit Vista or Windows 7”
    Works also for Windows 8.1.
[color=#000080]CP210x_VCP_Win2K_XP_S2K3.exe[/color]
  • Follow the instructions in the Release Notes.pdf and run this program to get the PCGU1000 working on 64-bit Windows 7, 8 and 8.1.
Here you can download detailed step-by-step instructions how to install the USB driver in Windows 7, 8 and 8.1: box.com/s/vh9olqyx3idhhxn8ujwm
The instructions are for other product but the installation principle is applicable for PCGU1000 too.
