I need some sweep in my wave sequence. Can I somehow use “Wave Sequence” tool in FGU.exe or do I have to write my own program by help of FGULink.dll?
There are alternative solutions depending the sweep length.
If only short sweep is needed you may do a sweeping library waveform and use it in “Wave Sequence” tool.
If you need long sweep then you have to use FGULink.DLL. I think it is not difficult. There in the example programs sweep is included.
You can’t use the “Wave Sequence” tool in FGU.exe.
