There is some problem in the 1k range, switching from 2k to 3k to 4k to 5k… there is a 1k waveform for 0.2-0.5 seconds between each 1k increment up to 9k. Running 10k to 50K with 1k increments works fine, it is the 2k-9k which has a problem.
The waveform shown:
-1kHz rise time 3uS for 3 seconds
-2kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 6uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-3kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 9uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-4kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 12uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-5kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 15uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-6kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 18uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-7kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 21uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-8kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 24uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-9kHz rise time 3uS for 3 seconds
[color=#BF0000]-1kHz rise time 27uS for 0.5 seconds (overlap error?) where is this comming from?[/color]
-10kHz rise time 3uS for 3 seconds
-11kHz rise time 3uS for 3 seconds
-12kHz rise time 3uS for 3 seconds
-13kHz rise time 3uS for 3 seconds
-50kHz rise time 3uS for 3 seconds
I want to do a Frequency sweep 1k-50k with a set rise time of 3uS using 1k increments. I had setup an Excel spread sheet to create each 1k increament LIB file using fixed 3uS rise time for a particular set frequency.
Example of the LIB files:
1k_3uS_50pDutyCycle.lib
0.0
(3)
1.0 (500)
(3)
0.0 (500)
2k_3uS_50pDutyCycle.lib
0.0
(6)
1.0 (500)
(6)
0.0 (500)
9k_3uS_50pDutyCycle.lib
0.0
(28)
1.0 (500)
(28)
0.0 (500)
10k_3uS_50pDutyCycle.lib
0.0
(32)
1.0 (500)
(32)
0.0 (500)
11k_3uS_50pDutyCycle.lib
0.0
(35)
1.0 (500)
(35)
0.0 (500)
50k_3uS_50pDutyCycle.lib
0.0
(214)
1.0 (500)
(214)
0.0 (500)
Wave sequence:
4 1000 0 1.69 3 1k_3uS_50pDutyCycle.lib
4 2000 0 1.69 3 2k_3uS_50pDutyCycle.lib
4 3000 0 1.69 3 3k_3uS_50pDutyCycle.lib
4 4000 0 1.69 3 4k_3uS_50pDutyCycle.lib
4 5000 0 1.69 3 5k_3uS_50pDutyCycle.lib
4 6000 0 1.69 3 6k_3uS_50pDutyCycle.lib
4 7000 0 1.69 3 7k_3uS_50pDutyCycle.lib
4 8000 0 1.69 3 8k_3uS_50pDutyCycle.lib
4 9000 0 1.69 3 9k_3uS_50pDutyCycle.lib
4 10000 0 1.69 3 10k_3uS_50pDutyCycle.lib
4 11000 0 1.69 3 11k_3uS_50pDutyCycle.lib
4 12000 0 1.69 3 12k_3uS_50pDutyCycle.lib
4 13000 0 1.69 3 13k_3uS_50pDutyCycle.lib
4 14000 0 1.69 3 14k_3uS_50pDutyCycle.lib
4 15000 0 1.69 3 15k_3uS_50pDutyCycle.lib
4 16000 0 1.69 3 16k_3uS_50pDutyCycle.lib
4 17000 0 1.69 3 17k_3uS_50pDutyCycle.lib
4 18000 0 1.69 3 18k_3uS_50pDutyCycle.lib
4 19000 0 1.69 3 19k_3uS_50pDutyCycle.lib
4 20000 0 1.69 3 20k_3uS_50pDutyCycle.lib
4 21000 0 1.69 3 21k_3uS_50pDutyCycle.lib
4 22000 0 1.69 3 22k_3uS_50pDutyCycle.lib
4 23000 0 1.69 3 23k_3uS_50pDutyCycle.lib
4 24000 0 1.69 3 24k_3uS_50pDutyCycle.lib
4 25000 0 1.69 3 25k_3uS_50pDutyCycle.lib
4 26000 0 1.69 3 26k_3uS_50pDutyCycle.lib
4 27000 0 1.69 3 27k_3uS_50pDutyCycle.lib
4 28000 0 1.69 3 28k_3uS_50pDutyCycle.lib
4 29000 0 1.69 3 29k_3uS_50pDutyCycle.lib
4 30000 0 1.69 3 30k_3uS_50pDutyCycle.lib
4 31000 0 1.69 3 31k_3uS_50pDutyCycle.lib
4 32000 0 1.69 3 32k_3uS_50pDutyCycle.lib
4 33000 0 1.69 3 33k_3uS_50pDutyCycle.lib
4 34000 0 1.69 3 34k_3uS_50pDutyCycle.lib
4 35000 0 1.69 3 35k_3uS_50pDutyCycle.lib
4 36000 0 1.69 3 36k_3uS_50pDutyCycle.lib
4 37000 0 1.69 3 37k_3uS_50pDutyCycle.lib
4 38000 0 1.69 3 38k_3uS_50pDutyCycle.lib
4 39000 0 1.69 3 39k_3uS_50pDutyCycle.lib
4 40000 0 1.69 3 40k_3uS_50pDutyCycle.lib
4 41000 0 1.69 3 41k_3uS_50pDutyCycle.lib
4 42000 0 1.69 3 42k_3uS_50pDutyCycle.lib
4 43000 0 1.69 3 43k_3uS_50pDutyCycle.lib
4 44000 0 1.69 3 44k_3uS_50pDutyCycle.lib
4 45000 0 1.69 3 45k_3uS_50pDutyCycle.lib
4 46000 0 1.69 3 46k_3uS_50pDutyCycle.lib
4 47000 0 1.69 3 47k_3uS_50pDutyCycle.lib
4 48000 0 1.69 3 48k_3uS_50pDutyCycle.lib
4 49000 0 1.69 3 49k_3uS_50pDutyCycle.lib
4 50000 0 1.69 3 50k_3uS_50pDutyCycle.lib
