Dear support team,
I’m considering to use a PCGU1000 in a project, which requires:
[ul]
[li]generating a sine wave with arbitrary phase to the sync pulse[/li]
[li]output of a TTL sync pulse with a small (<5%) duty ratio.[/li][/ul]
The first point can be solved like in thread “Instruments » PC Generators » Configurable phase shift for the two outputs of PCGU1000?”, but is it possible to achieve a low duty ratio, maybe by modifying the firmware?
I had the idea this could be possible after reading the thread “Instruments » PC Generators » PCGU1000 limits”, where inverting the sync pulse logic was accomplished by a firmware change.
Best regards,
Adam
