I’d like to use the PCGU1000 to generate a waveform for testing IGBTs. To do this, I’ll need to generate an arbitrary waveform that repeats for only a single period, or one-shot.
I’ve created a waveform consisting of 1 V for 1 ms, 0 V for 100 us, 1 V for 100 us and then off for a long period of time by making my own .lib file. How can I get this waveform to repeat only once and on my command using the PCGU1000.
You can use Repetition interval setting to repeat one cycle of signal waveform with selectable interval.
Click “More Funct.” button, check the Repetition interval check box and then enter the interval time in milliseconds and press Enter.
Set the repetition interval to 1000000ms.
Then you get a single period of the loaded library waveform by pressing and then releasing the “More Funct.” button.
