PCGU1000--Radar Pulse Generation
Is it possible to create a 1 usec pulse width, 1% duty cycle waveform?
Is it possible to set the output to a DC value to represent CW?
Thanks,
Ed
[quote]Is it possible to create a 1 usec pulse width, 1% duty cycle waveform?[/quote]Yes, it is.
Download and install the latest PcLab2000SE version 4.05 from: velleman.eu/support/download … 1000&type=
In the function generator select square wave 10kHz.
Adjust the duty cycle to 1% (use mouse wheel to adjust).
You’ll get 1us pulses with 1% duty cycle.
[quote]Is it possible to set the output to a DC value to represent CW?[/quote] Yes.
Select MORE FUNCT button and then select + or - DC button.
Together with the offset adjustment you’ll get up to +10V/-10V DC output.
Thanks!
Is it possible to do the same thing thru the DLL?
Ed
I’m sorry this is not possible thru the DLL.
There are no duty cycle and no DC options.
