Is there possibility to generate signals lower than 10mHz?
I have need for 1mHz, not lower.
If you need sine wave then you can get the 1mHz using the sweep mode.
Set both the start and the stop frequencies to 0.001.
If you need other waveforms too then you need a slightly modified program that allows output of such a low frequency.
Thank you for your reply!
Yes, i need only sine wave.
