I’m fitting a PCGU1000 with some other kit (VM167 etc) into a 19" enclosure. Is the case critical for screening or can I just mount the bare board? I’m only going to be running to probably 100KHz but will EM noise from other things like the SMPS affect it’s operation?
Many Thanks.
Ian
The PCGU1000 is not very sensitive to external EM noise. I think you can put the bare board to the 19" enclosure.
Thank you very much for the answer. Ian
