PCGU1000 drive capability
Dear Sir,
i need to know what are the max current the Generator can source at High Level and sink at Low Level (0V).
I need to use a square wave for a circuit that needs at leat 15Vmin in the High Level (and less than 5Vmax in the low level)
and it is powered by a truck battery (24 - 28V); have you any suggestion on how to couple the output of the PCSU1000 to this circuit ?
Thank you for your support
Regards
The output resistance of the generator is 50 ohms.
The output current from the signal output at 10Vpp is 70mA AC when short circuited.
The DC output current at 5V DC offset is 87mA when short circuited.
[quote]i need to know what are the max current the Generator can source at High Level and sink at Low Level (0V).[/quote]I do not recommend to feed any external current to the generator output.
[quote]I need to use a square wave for a circuit that needs at leat 15Vmin in the High Level (and less than 5Vmax in the low level)
and it is powered by a truck battery (24 - 28V); have you any suggestion on how to couple the output of the PCSU1000 to this circuit ?[/quote]This is possible (only) by using a a capacitor as the coupling element between the generator output and your circuit.
Also it seems your required wave amplitude is >10Vpp. The maximum amplitude from the PCGU1000 is 10Vpp.
