I’ve bought this generator after being impressed with PCSU1000 oscilloscope and with fast feedback from velleman software developers.
Thanks!
I think it would be useful to add slider to change rise/fall time proportion in triangle shape mode. To make shape not only “//”, but also “/|/|” or “||”.
Just like it’s implemented in square mode. -
When connected with PCSU1000 oscilloscope, I can analize responce in fixed regions (1KHz…10KHz, 1KHz…100KHz). But it’s rather hard to analize custom narrow band (for example 9…11KHz) in details.
Can you add ability to set custom Start and Stop frequencies (and custom frequency step)?
- It would be very useful to add “import waveform” from sound *.wav mono file. File can be truncated to first 8196 samples (or time-scaled to fit in this buffer, as an option).
There are some very useful audio editors (like AdobeAudition), where I can generate for example “brown”, “pink” or “white” noise, create sin() waveform with several harmonics combined…
I don’t ask to implement everithing in your software, I only want to prepare sample in audio editor and import it in generator buffer.
