PCGU 1000 question about time delay and signal duration
we just have 2 problems with the function generator PCGU 1000:
1 we found that there is always a short delay between setting up parameters on the control panel and the generation of signals.
2 when we want to generate short pulses for such as 0.5 sec, the real duration is much longer than that.
Perhaps these problems are due to the USB transition time. Is there any way to solve them?
Thanks!
[quote]1 we found that there is always a short delay between setting up parameters on the control panel and the generation of signals. [/quote]The waveform update is time consuming process (about 0.5 sec). This is why the waveform settings are not updated continuously but after a short delay.
[quote]2 when we want to generate short pulses for such as 0.5 sec, the real duration is much longer than that.[/quote]I’m sorry but there is always the time required about 0.5 seconds to upload the waveform data to the generator.
[quote]Perhaps these problems are due to the USB transition time.[/quote]Yes.
viewtopic.php?f=11&t=8417
