PCGU 1000, Frequency resolution
Hello there,
we wonder what the PCGU1000 is capable of resolving what frequency ranges.
For example: If we set 100’000 Hz (100kHz) is the PCGU also capable of resolving 100’001 Hz or 100’005 Hz? Or will those frequencies be rounded?
What are its limitations in what frequency range? Is there some kind of table or documentation? What I mean is does it work like: The lower the frequency the higher the resolution and the higher the frequency the lower the resolution?
Thanks for your help! :slight_smile:
Mario
Here is the resolution on different frequency ranges of the PCGU1000:
Range/Hz Resolution 0.1 0.00001 Hz 1 0.0001 Hz 10 0.0001 Hz 100 0.0001 Hz 1k 0.0001 Hz 10k 0.0001 Hz 100k 0.0001 kHz 2M 0.0001 kHz
When using the FGULink.DLL, the resolution is 0.001Hz on all ranges.
Great, thanks for the list. :slight_smile:
