I try to install the pcg10 on a laptop witouth parallel port.
I take a USB->Parallel port converter (UTM1925) and when I launch the pc lab software I got this message :
“Access violation at address 004086AF in module’Pc_Lab2000se.exe’. Read of address 00000010”
Any solution ??
The PCG10 PC generator is not compatible with a USB/parallel converter.
is there a solution for a laptop without parallel port ?
Is that working with Exsys EX-1536 PCMCIA Adaptor ?
http://www.exsys-addon.fr/products/ex_1356.htm
We have no experience with such a device.
The PCMCIA don’t work, I finally use the notebook with the parallel port of the docking station and is working well, thy for all
I also need such a solution. What kind of docking station do you use ?
VEL436
9
It seems that there are some PCMCIA Parallel port cards that do the job too.
See the thread: forum.velleman.be/viewtopic.php? … a05c9bacc9
