PC no detect 8055
The PC with windows XP does not detect to me the card " Card 0 not found ". The assembly(montage) is correct. When it I connect to USB there is ignited the led LD11, LD8 it(he,she) blinks two times and the third time remains fixed ignition. Agradecere they help me. Thank you
After plugging the unit to the USB socket of the PC the LED LD8 should give three flashes and stay OFF. If it stays ON then the card is not detected by the PC.
Please check this thread for more info: K8055 Problem - LD8 Lit
