Hi all,
I’ve just received a PS1503SB DC generator. I’m new to this kind of device, but when I measure the output voltage with a simple multimeter (which is working ok), the value is systematically 3x higher on the multimeter than on the supply…
Is there any explanation or should I return it directly to the after sales ?!!
Thanks for any help
Flehaire
This forum is for Velleman projects only.
You should post you question in the link below.
