hej
I like to know that on the circuit board the part TS is supplied in the kit
or do you need to buy it on your own
thanks
[size=85]*im a dutchmen I try to speak english[/size]
hej
thanks
TS is an optional temperature sensor. Velleman part n° is THERMIC.
There is no need to add it, it will work without.
ok thanks
and an other question for the k4006
witch is the voltage you need to supply on the kit is it 230V/50Hz
