bonjour,
j’aimerais connaitre le paramétrage des fusibles utilisés pour le pic 16F886 sur la platine expérimentation afin de développer mes propres applications.
cordialement
The following configurations are used in the examples for the 16F882:
ASM examples:__CONFIG _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
__CONFIG _CONFIG2, _WRT_OFF & _BOR21V
C examples:#pragma config CPD = OFF
#pragma config BOREN = OFF
#pragma config IESO = OFF
#pragma config DEBUG = OFF
#pragma config FOSC = INTRC_NOCLKOUT
#pragma config FCMEN = OFF
#pragma config MCLRE = ON
#pragma config WDTE = OFF
#pragma config CP = OFF
#pragma config LVP = OFF
#pragma config PWRTE = OFF
#pragma config BOR4V = BOR21V
#pragma config WRT = OFF
The configuration bits for the 16F886 you’ll find in the file P16F886.INC
If you have installed MPLAB IDE you’ll find the file in the folder:
C:\Program Files (x86)\Microchip\MPASM Suite
or
C:\Program Files\Microchip\MPASM Suite
[code];==========================================================================
; Configuration Bits
; NAME Address
; CONFIG1 2007h
; CONFIG2 2008h
; The following is an assignment of address values for all of the
; configuration registers for the purpose of table reads
_CONFIG1 EQU H’2007’
_CONFIG2 EQU H’2008’
;----- CONFIG1 Options --------------------------------------------------
_FOSC_LP EQU H’3FF8’ ; LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_LP_OSC EQU H’3FF8’ ; LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_FOSC_XT EQU H’3FF9’ ; XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_XT_OSC EQU H’3FF9’ ; XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_FOSC_HS EQU H’3FFA’ ; HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_HS_OSC EQU H’3FFA’ ; HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_FOSC_EC EQU H’3FFB’ ; EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
_EC_OSC EQU H’3FFB’ ; EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
_FOSC_INTRC_NOCLKOUT EQU H’3FFC’ ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_INTRC_OSC_NOCLKOUT EQU H’3FFC’ ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_INTOSCIO EQU H’3FFC’ ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_FOSC_INTRC_CLKOUT EQU H’3FFD’ ; INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_INTRC_OSC_CLKOUT EQU H’3FFD’ ; INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_INTOSC EQU H’3FFD’ ; INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_FOSC_EXTRC_NOCLKOUT EQU H’3FFE’ ; RCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_EXTRC_OSC_NOCLKOUT EQU H’3FFE’ ; RCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_EXTRCIO EQU H’3FFE’ ; RCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_FOSC_EXTRC_CLKOUT EQU H’3FFF’ ; RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_EXTRC_OSC_CLKOUT EQU H’3FFF’ ; RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_EXTRC EQU H’3FFF’ ; RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, RC on RA7/OSC1/CLKIN
_WDTE_OFF EQU H’3FF7’ ; WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
_WDT_OFF EQU H’3FF7’ ; WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
_WDTE_ON EQU H’3FFF’ ; WDT enabled
_WDT_ON EQU H’3FFF’ ; WDT enabled
_PWRTE_ON EQU H’3FEF’ ; PWRT enabled
_PWRTE_OFF EQU H’3FFF’ ; PWRT disabled
_MCLRE_OFF EQU H’3FDF’ ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
_MCLRE_ON EQU H’3FFF’ ; RE3/MCLR pin function is MCLR
_CP_ON EQU H’3FBF’ ; Program memory code protection is enabled
_CP_OFF EQU H’3FFF’ ; Program memory code protection is disabled
_CPD_ON EQU H’3F7F’ ; Data memory code protection is enabled
_CPD_OFF EQU H’3FFF’ ; Data memory code protection is disabled
_BOREN_OFF EQU H’3CFF’ ; BOR disabled
_BOR_OFF EQU H’3CFF’ ; BOR disabled
_BOREN_SBODEN EQU H’3DFF’ ; BOR controlled by SBOREN bit of the PCON register
_BOR_SBODEN EQU H’3DFF’ ; BOR controlled by SBOREN bit of the PCON register
_BOREN_NSLEEP EQU H’3EFF’ ; BOR enabled during operation and disabled in Sleep
_BOR_NSLEEP EQU H’3EFF’ ; BOR enabled during operation and disabled in Sleep
_BOREN_ON EQU H’3FFF’ ; BOR enabled
_BOR_ON EQU H’3FFF’ ; BOR enabled
_IESO_OFF EQU H’3BFF’ ; Internal/External Switchover mode is disabled
_IESO_ON EQU H’3FFF’ ; Internal/External Switchover mode is enabled
_FCMEN_OFF EQU H’37FF’ ; Fail-Safe Clock Monitor is disabled
_FCMEN_ON EQU H’3FFF’ ; Fail-Safe Clock Monitor is enabled
_LVP_OFF EQU H’2FFF’ ; RB3 pin has digital I/O, HV on MCLR must be used for programming
_LVP_ON EQU H’3FFF’ ; RB3/PGM pin has PGM function, low voltage programming enabled
_DEBUG_ON EQU H’1FFF’ ; In_Circuit Debugger enabled, RB6/ICSPCLK and RB7/ICSPDAT are dedicated to the debugger
_DEBUG_OFF EQU H’3FFF’ ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
;----- CONFIG2 Options --------------------------------------------------
_BOR4V_BOR21V EQU H’3EFF’ ; Brown-out Reset set to 2.1V
_BOR4V_BOR40V EQU H’3FFF’ ; Brown-out Reset set to 4.0V
_WRT_HALF EQU H’39FF’ ; 0000h to 0FFFh write protected, 1000h to 1FFFh may be modified by EECON control
_WRT_1FOURTH EQU H’3BFF’ ; 0000h to 07FFh write protected, 0800h to 1FFFh may be modified by EECON control
_WRT_256 EQU H’3DFF’ ; 0000h to 00FFh write protected, 0100h to 1FFFh may be modified by EECON control
_WRT_OFF EQU H’3FFF’ ; Write protection off[/code]
merci
