Panel Thermostat Module VM148
I would like to buy this module, but the sensor will be about 1 meter away from the module. I saw in the general description that the cable of the included sensor is only 20 cm long, and with a connector. Will the module still work correctly if I make this cable longer? Thanks for your answer. Greetings, Bart
You can extend the cable, 1 or 2m can’t be a problem.
