I’m working on an MP3 radio for my small one based on the P8095-4 kit. I started with the kit and it worked fine, so I concentrated on the housing and periphery. Now, that I have everything together, there is a problem.
I can turn on the kit and the red LED is on. Even without starting playback, the voltage regulators and the amplifier get very hot. When I turn on playback using the Play/Pause button, I can hear a whistling noise on both channels with decreasing frequency and volume. Again, the voltage regulators and the amp get very hot. There is no sound from an MP3 and I did not run it in that state longer than 10s.
Do you have an idea, what the problem could originate from?
Best regards, Andreas
