I have been using my 8055 board on and off for 6 months using it to do some automation work without any problems until yesterday, I was doing some work with the P8048 PIC programmer and when I had finished I connected the 8055 and noticed that the test LED flashed as normal but this time it did not go out. I then found that I could not connect to the board nor anything else connected to the computer by USB.
I have tested the board by connecting 5v DC and again the LED flashes and then stays lit.
Is there away of testing the 8055 board and the PIC?
If I put the PIC from the 8055 in to the PIC programmer and up load the program from it what should I see?
JSK90
