Hello I am a complete novice wrt pics so this may well be a daft question but here it is… What is the max resolution the p8048’1 board will program please?
Also are there any projects or pre-written codes for a variable duty cycle pwm, controllable with tactile switches? I am planning to use my new pic programmer to program a pic for 2 pwm outputs to control a variable bench psu. As my main aim at present is to complete the design process of the afore mentioned power supply, it would be preferable for now to use a code I could copy and tune the frequency to a desired level. I would like to use a 10 BIT pic to give 512 steps for 0 to 100% duty cycle. Is this possible with this programmer? Thanks for reading
