P8048'1 VM111 Bit by Bit assembler code study
I have just loaded the demo code for chasing LED’s, all works perfectly. I have read the data sheet for 16F627 and absorbed about 10% of it while trying to find each one of the operation codes that were used in the demo I loaded. I am hungry for more 16F627 asm files for standard functions, such as, an event counter where I can use one of the push buttons as the event trigger, count the number of times it is pushed and then give a result with an LED when it reaches a preset number, but it must be for 16F627 because that is the one I have on the VM111 kit.
Does anyone have some code for this kind of study please?
Hello, anyone !
Yes, i know it’s a little late, answering this topic, but perhaps somebody would find it useful ?
I have done a little programming:
;=	EVENTCOUNTER FOR PIC16F627 AND K 8048 / VM 111					=
;=	BY BRUSHLESS 333, 28/6-'14.							=
		INCLUDE p16f627.inc
	__CONFIG        _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
;       Variable Definition								=
		CBLOCK	H'0020'
TIMER1
TIMER2
UPCOUNTER
REG_1
		ENDC
SW1	EQU	0
SW2	EQU	1
LD1	EQU	0
LD2	EQU	1
		ORG	0		; Reset vector address
		GOTO	BOOT		; Go to boot-sequence...
;=		DELAY-ROUTINE - about 50 msec's at 4 MHz clock				=
DELAY_50ms      MOVLW   D'050'
                MOVWF   TIMER2
DEL_LOOP1       MOVLW   D'250'
                MOVWF   TIMER1
DEL_LOOP2    	NOP
		DECFSZ  TIMER1,F
		GOTO    DEL_LOOP2
                DECFSZ  TIMER2,F
                GOTO    DEL_LOOP1
		RETLW   0
;=		BOOT-SEQUENCE								=
BOOT		MOVLW	B'00000111'	;Disable Comparator module's
		MOVWF	CMCON
		BSF	STATUS,RP0	;Switch to register bank 1
					;Disable pull-ups
					;INT on rising edge
					;TMR0 to CLKOUT
					;TMR0 Incr low2high trans.
					;Prescaler assign to Timer0
					;Prescaler rate is 1:256
		MOVLW	B'11010111'	;Set PIC options (See datasheet).
		MOVWF	OPTION_REG	;Write the OPTION register.
		CLRF	INTCON		;Disable interrupts
		MOVLW	B'11000000'
		MOVWF	TRISB		;RB7 & RB6 are inputs - RB5...RB0 are outputs...
		MOVLW	B'11111111'	;Make PORTA all inputs...
		MOVWF	TRISA
		BCF	STATUS,RP0	;Switch Back to reg. Bank 0
		CLRF	PORTB		; resets all outputs...
		CLRF	UPCOUNTER	; ensures, that the counter starts from zero, after power-on...
		CLRF	REG_1
;=		PROGRAM STARTS HERE							=
BEGINNING	CALL	DELAY_50ms	; short break...
		BTFSC	PORTA,SW1	; testing for released SW1...
		GOTO	$-1		; ( circulates through these two instructions, until button is released )
		BCF	PORTB,LD1	; indicates a released button...
		BTFSC	REG_1,0		; checks what to do - test for "clock-pulse" to the upcounter, or test for manual reset of the completed cycle...
		GOTO	CHECK_SW2
		CALL	DELAY_50ms	; short break, in order to prevent any false triggering due to contact bounce...
		BTFSS	PORTA,SW1       ; testing for an activated SW1...
		GOTO	$-1		; ( circulates through these two instructions, until button is depressed )
		BSF	PORTB,LD1	; indicates an activated button...
		INCF	UPCOUNTER,F	; increments the counter one step...
		MOVLW	D'010'		; ( this value can be between 1-255 )
		SUBWF	UPCOUNTER,W
		BTFSS	STATUS,Z	; tests for an "overflow"...
		GOTO	BEGINNING	; if none, go back and test SW1 again...
		BSF	PORTB,LD2	; turns on LD2, when the specified number of cycles is completed...
		BSF	REG_1,0		; sets a controlbit for "mission accomplished"
		GOTO	BEGINNING	; go back, and see what to do next...
;-------------- CHECK FOR RESET ---------------------------------------------------------
CHECK_SW2	BTFSC	PORTA,SW2	; checks for released SW2...
		GOTO	$-1
		CALL	DELAY_50ms
		BTFSS	PORTA,SW2	; waits for a manual reset on SW2...
		GOTO	$-1		; and carries on, when you are ready to start over again...
		BCF	PORTB,LD2	; turns off LD2
		CLRF	UPCOUNTER	; resets the upcounter...
		BCF	REG_1,0		; resets controlbit...
		CALL	DELAY_50ms
		GOTO	BEGINNING	; now, all is cleared up, nice and tidy, and we make a new start...
		END
It’s important to have the p16f627.inc file copied from the include-folder to the examples-folder, in
order to make the ASSEMBLER-software able to find it !
