Overextrusion only on 1 Side?
Hi Guys,
has anyone an idea why my K8400 does this?
I have a K8400 without heated bed and only 1 extruder.
Printing with Cura Standalone Software Version 3.0.3
https://ibb.co/gZemmR
Thx for any help =)
What are you printing with?
PLA or ABS?
What temp are you using?
PLA 190C ABS 220C
Are you using the software from the link below?
http://www.vellemanprojects.eu/downloads/files/vertex/software/vertex-3d-printer-repetier-host-1-0-6.zip
Hi Wrong_Way,
thank you for replying :slight_smile:
I am using PLA 1.75 and at the moment i am printing with 190C
I am using the standalone cura engine 3.0.3 from ultimaker. at first i used the repetier software but the prints i got back then were even worse… :frowning:
If you are new to 3d printing you should use the software from the link above.
This has been setup for the K8400
even if i get better results with the other software? :wink:
