Optimal retraction settings
I’ve been suffering from stringing and not so brilliant bridging, so am looking for advice on retraction settings/speeds etc. I currently use the following:
Slicer: CURA
Layer height: 0.15mm
Travel speed: 100 mm/s
Print speed: 30mm/s
Retraction speed: 65mm/s
Retraction length: 5mm
Zhop: .075mm
Flow: 115%
PLA print temp: 190 degrees
I’m using the stock head
Any suggestions would be most welcome. The Zhop has helped a lot, but would like to find optimal settings
