Optical endstop
Hello
I would like tu install optical endstop on X and Y axis and maybe Z axis
But i don’t know how to install it…
Can somebody explain me how to connect it to mother boar with photos if possible
And witch are the changes to make in Marlin V2 firmware
Thanks for your help
Schematics of a Sanguinololu board can be found with google.
The main thing is you have to do some soldering on the board to make the 3wire connector on the board accept a 3 wire optoelelectric endstop. But it can be done and it works.
Before proceeding: do you know if the endstop is designed for 5V or 12V?
Robert
this would be a possible layout for such an endstop. Note that the ordering of the contacts is different from the one on the K8200/3drag controller (±S vs. S±). Also, the printer may have problems when operated in a room with (too much) sunlight.
Cheers,
kuraasu
thanks for your answer
i will look at that as soon as possible
