An open collector is a transistor output.
The transistor’s “collector” contact is used as a kind of switch.
The collector contact must be used in a circuit, appying voltage, resulting in a current (max 50 or 100mA)
Note that collector outputs are generally not isolated from the circuit and are using a common ground.
