NTC resistor
Is it a problem if my NTC is about 115 ohm?
At room temp it should be around 100K.
Is it shorting out somewhere?
No its not. I checked everything. And even if it would, the resistance would be 0. Never the less, it kind of works. My problem now is that all my temperatures are about 38°C to high (both, the extruder and the bed).
When you measured the resistance of the thermistor was it still connected to the board?
No it wasn’t
