Nozzle
Hello
I would like to know if you think to sell a more little nozzle than 0.5mm ?
Else there is a nozzle 0.4 or 0.35 compatible with k8200 ?
Somebody have try other nozzle on this printer ?
Best regards
I have ordered 0.35 but the results are not better then the original 0.5 I printed two test cubes with the same settings and the one with 0.35 had a lot of hair treads in a hole that is in the middle of the test cube.
Also the thread of the nozzle was a little different and I can not use it anymore with the original but I have three therefore I keep this as spare I purchased two in Italy from 3drag the temp sensor is build in.
mijnalbum.nl/Album=WXK3OIE4
Thanks for you answer and your test, it’s a good test but have you change parameters in repetier and slic3r for testing 0.35 nozzle because paramaters can’t be the same than 0.5 nozzle.
I have seen this nozzle in 0.35
cgi.ebay.fr/ws/eBayISAPI.dll?Vie … 1436.l2649
I don’t know if this is ok for K8200 because seller say me i need to have a M6 thread and i don’t know if k8200 have a M6 thread for nozzle…
Somebody can inform me ?
Best regards
Be careful if you have only one extruder the thread is also 6 mm but the thread distance is not the same and it will need force to mount the nozzle and you will not be able to re install the Velleman nozzle.
thanks for informations bour12
but do you know the original thread distance ?
Have you got a link where i can buy a good 0.35 nozzle or 0.4 nozzle for K8200 ?
Original thread of the nozzle is M6x0,75 (fine thread). Normal M6 doesn’t fit.
Best regards
Ok thanks for advertising.
But it is possible to change total extruder for another not Velleman? for example a rewrap extruder
it is possible or not?
Somebody have change original extruder for another not Velleman?
