Nozzle temperature versus requested temperature
I have done a nozzle temperature check to see if the requested temp. is really what we get.
I have found in fact that the real temperature if alway higher that the one requested.
here is the mapping curve: real temp = 1.12*(requested temp)-3.18
[/URL]
it give more or less 10°c-30°C of difference between requested temp. and real one between 100°c and 250°c
how can I calibrate the thermistor directly in the machine.
I already look at the PID but the calibration is more related to the temperature reading.
Thank for help
Cedric
Have you correctly installed the thermistor? If not you can get easily a difference of 10 - 30 °C.
Dylan
Hi Dylan,
Yes, I was aware of such problem in case of sensor bad location.
for me, this coud be easily corrected if I could know where to enter the correction factor, if one is existing.
thank for your help
cedric
I think you have to modify the firmware then, there’s no option to do this in Cura/Repetier/…
Dylan
The values are in the “thermistortable.h” file in the Marlin firmware. You can choose from the existing table or create a new one.
