I’ve got some issues with my k8400. The nozzle seems to smudge the layers. You can see trails sometimes on the second layer and it gets worse after about 20 layers.
It is almost like the print bed can’t move in time before the head moves to the next step.
I have checked the Z motor and rod, it can move with ease and works fine if i do steps in repetier. The bed is perfectly leveled at 0.3 mm.
worth noting is that this seems to have solved my y axis that skipped sometimes. Just to be more on the safe side i loosened the tension on the belts a little and now i got 2 x flawless 4 hour prints.
thx for the help
[quote=“exustio”]worth noting is that this seems to have solved my y axis that skipped sometimes. Just to be more on the safe side i loosened the tension on the belts a little and now i got 2 x flawless 4 hour prints.
thx for the help :D[/quote]
