I use PLA at 190°C and HIP support at 225°C with two nozzles.
In dual head mode, it heats up the PLA nozzle, makes the first layer and then moves to one side to heat the HIP nozzle. The only problem is that the HIP nozzle gets up to temperature (to the point where the heater LED begins to flicker) and the printer doesn’t begin printing.
This does not occur when the nozzle heats up to load the HIP (Using the ‘Load ABS’ function), perhaps due to the different temperature.
I reduced the temperature in the first place to try and fix the HIP from oxidising and turning black [color=#0000FF](forum topic)[/color], but also because lower temperatures provide a number of other benefits.
