I have a Vertex with two nozzle. I print PLA at 195°C. ( Thanks to Raby )
Since a few days Nozzle 1 is not able to maintain the temperature. After a few minutes, the temperature drops to room temperature and the printer continues to “print” without filament.
I have not updated the orginal firm ware…could this be the problem?
[quote=“kris.battheu”]I have not updated the orginal firm ware…could this be the problem?[/quote]Nope it never happened with it. When the temperature drops, is the red LED still lit on the U-shaped PCB? It could be a bad contact. Check all connections and connectors.
From your video it seems the problem lies with the heater : when hot there must be a break in the circuit : check the integrity of the wires. If they’re OK then you might have a bad heater cartridge.
