Im trying to print a S3 Case and its not printing right
I had Posted before the the same problem and they said it was the belts i already tightened em and it still did the same and i loosened em and i still cant get it to print right
Did you get any end-stop hits? Check the log file.
Upgrading to firmware V2 can help to avoid this.
Make sure all stepper drivers are set to 0.5V-0.55V and make sure all motors turn smoothly.
From your picture and the fact that V2 was the fix you still may have a problem.
Make sure the 2 wires for the Y end stop are not rubbing on the frame in the back of the machine.
