The extruder motor is turning i think. I can see the wheel moving a few times to feed the printhead. The wheel is not turning all the time. Tried to push the filament manually but its not possible…
Take a marker and draw a line on the shaft and pulley
Then start your print.
Watch the extruder and make sure the pulley is not slipping on the shaft.
When you put the tubing in the hot end did you push it all the way down?
tried to hold a flashlight under the nozzle to see if i can see true it. This is imossible. So i think my nozzle is constipated. Any suggestions on how to clean it?
Unscrewd the screw on top of the printerhead and pushed a needle from the nozzle to above. There was a piece of pla stuck in the printerhead… Hope this problem is solved by now and i can now start enjoying my printer finally.
Any tips on how to avoid pla getting stuck in the printerhead?
I have not had problems with filament jamming in the feed tube or the print head. However, I have noticed that some brands of filament work better than others. Humidity (either too high or too low) can affect the filament’s flexibility. If your filament gets too dry, it can become brittle and more prone to breakage and jamming of the tube.
If you bend the filament in your fingers, it should bend. If it snaps like uncooked spaghetti then you may wish to try a fresh spool.
It is also possible that you have some burnt material partially clogging your extruder. If you raise the printhead, heat it, and extrude some material, it should come out easily and with a nice round bead. If the thread appears thin, or if it curls to one side, you may need to clean the nozzle.
