Hello all,
printer has been built, but still lot of to do…
The most serious problem: printer does not recognize the inserted SD card…
I have checked wiring, disassembled the LCD block, checked/measure the mechanical switch…working.
What else to check? Any advice?
To be honest, I do not have a “genuine” SD card, but Micro SD in adapter, I have tried 1GB and 8GB…
J.
You have to slice your project first and put the G-Code on the SD card.
If it still does not see the card you will need to init the card (this is in the menu)
